    Pont du Gard
    57 Posts 15 Posters 11.1k Views 15 Watching
      GreyHead
      Most likely you need to select "Export default UVs" as 'Yes' when you export to Kerkythea from SketchUp. If the UVs aren't exported then KT uses settings of its own.
      The picture on the left has the default settings and some textures are large and others small. The one on the right uses the SU mapping (though some textures are missing in this case - it's the earlier version of he model posted below).
      Bob
        Julius
        Bob
        mmm...that doesn't seem to solve the problem, on the contrary...
        the attached image below shows the model exported in KT with UVs:
        http://img396.imageshack.us/img396/9346/withuvshz0.jpg
          GreyHead
          Interesting . . . scratches head . . .
          Bob
          Julius, have sent you a pm.
          • FrederikF Offline
            Frederik
            Julius - sorry for my ignorance, but how have you applied the textures..??
            And have you tried exporting to an OBJ-file, instead of using the SU2KT..??
            Reason for asking is that SU2KT can't handle some parts of SU texturing very good (i.e. Photomatch)...
            Can't you post your scene or a part of it at the KT Forum..??
            I'm sure that someone will be happy to debug this... 😉
            Cheers
            Kim Frederik
              Julius
              with the bucket tool and then i adjusted the position.( 💚 )
              since i use SU free version i can't export to OBJ.
              here i didn't use photomatch.
              if you insist... 💚
                remus
                If you want you could PM me the new file with the updated textures and i'll export it as an obj.
                  pichuneke
                  I had the same problem with the textures in my roman theatre of orange. I am working in a better version, I will have to ask for someone to export it to .obj when finished.
                  Forgive my spanglish...
                  • FrederikF Offline
                    Frederik
                    @julius said:
                    if you insist... 💚
                    I do... 😉
                    Aaahhh yeah - I remember that... 😉
                    I explained this to you in the Roman theatre of Orange (France) Today.... 😄
                    If it doesn't breach any copyright issues, I have no problem doing it for you... 😉
                    Cheers
                    Kim Frederik
                      pichuneke
                      I don't know how it may break any copyright issues. The model is made by me, it is freely downloadable from 3D Warehouse, all the images for the textures have authorization of use by their owners...
                      Anyway I won the prize and I am going to Orange at the end of the month. I'll take a lot of photos, I may even use my own textures 😄
                      France must be frightened. Pichuneke arrives 💚
                        GreyHead
                        Congratulations on the Prize!! France quakes . . .
                        I've been playing with this model, mostly blindly groping. Exporting directly to KT seems to lose the UV mapping, the textures are still there but the scaling is badly out. Exporting via obj keeps the textures beautifully but some other artifacts appear in side the arches.
                        Bob
                          Julius
                          I'm glad to announce that i finshed the bridge!!! ☀
                          you can download it at the first post.
                          the big change are the textures: i spent a lot of time positioning them.
                            pichuneke
                            Julius, the first arc I "visited":
                            http://i28.tinypic.com/qn4rdf.jpg
                            I believe that it is a mistake...
                              Julius
                              unfortunately not...i know that arch looks wierd, but i didn't know how to do to make it looks good. maybe i will have to draw it again. apart from that, everything is fine? 😒
                                pichuneke
                                Everything is fantastic!
                                Forgive me, when I upload a render, what I want is that people tell me what mistakes I have done. I don't want congratulations and things like that, and I forgive to say it to the people.
                                But is going to be one of the more visited models of 3D Warehouse. Congratulations 😄
                                You must inform the owner of the group of UNESCO sites to add your model:
                                Error 404 (Not Found)!!1
                                (sketchup.google.com)
                                It's one of the most interesting collections I have seen in 3D Warehouse.
                                  Julius
                                  don't worry, it's good you criticized that arch, so i know i'll have to edit it (even though it's not a funny thing 😡 😉 )
                                  about the unesco thing...why not? but first i have to modify that arch.
                                    pichuneke
                                    My english is rusty and limited.
                                    I don't forgive. I forget. 😳 😆
                                    I don't want congratulations and things like that, and I forget to say it to the people.
                                    That's what I wanted to say.
                                      Jorgensen
                                      Funny to see, I was there last summer 😄
                                      Notice the prehistoric looking forest. Almost expected an dinosaurus to show up 😲
                                        Julius
                                        nice pics!
                                        i edited the arch: check it out and tell me what you think.
                                          pichuneke
                                          Much better 😄
                                          There is a lost single line at the bottom of the model, under an arc.
                                            Julius
                                            @pichuneke said:
                                            Much better 😄
                                            i know: the purpose of that line is to rotate correctly the model when i import the google earth terrain, and then to rotate it back when i want to edit it so that it's aligned with the axis.
                                            • 2 / 3
