    Pont du Gard
    57 Posts 15 Posters 11.1k Views 15 Watching
    • E Offline
      el.antuan
      Great model, Julius!
      I like it! 😄
      regards...
      "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
        Julius
        thank you! ☀
        @gjenio said:
        Gran bel lavoro, complimenti!
        Only one suggestion:
        I would have used radial brick texture on the arcs
        i thought about that... but how can that be done?
        i was wondering whether i should post this model in the special interest user group "Archaeological & Historical Reconstruction".
        i've noticed that there isn't a model of this bridge on google earth yet. do you think i should notify it to someone of the google team? (for example Craig...).
          remus
          For the radial brick texture you can either amke a curved texture outside of SU and the apply it to the face, or alternatively you can split the arc in to lots of sections and then rotate a texture to get a radial effect.
          Very nice model btw, i love the detail.
          If you want to get this on google earth youll ahve to cut down the model size a lot, Probably the easiest way to do this is to use projected textures for most of the faces as opposed to modelling all the details (as fun as it is 😛)
            pichuneke
            Very good work 😉
            Forgive my spanglish...
              Cool ☀ (model by Julius of course 😄
                Julius
                yes, next step will be rendering! (but in KT)
                  Hi Julius,
                  Nice model, really! I have positioned (rotated radially) the texture on the arch for you hoping that you used the same component at least on that storey... 😳 but then I realised that I edited the one unique arch and then I was too lazy to do the job elsewhere, too.
                  Also, the positioning could have been done more nicely...
                  Well, anyway, this is basically the way to adjust the arch if you do not have a ready-to-use arch material.
                  Note that you seem to have applied the material from outside the components' context, you will have to apply it onto the individual faces one-by-one first to be able to position it.
                  Pont du Gard for Google Earth (model only).skp
                    Julius
                    @gaieus said:
                    Hi Julius,
                    Nice model, really!
                    i'm glad to hear you like the model.
                    @gaieus said:
                    I have positioned (rotated radially) the texture on the arch for you hoping that you used the same component at least on that storey...😳 but then I realised that I edited the one unique arch and then I was too lazy to do the job elsewhere, too.
                    i must admit i did quite a mess with components...
                    thank you very much! yes, it could have been positioned more nicely, but it doesn't matter, you did a great job...but...i'm too stupid to understand how you positioned the material 😳 ...
                    this is because i added the texture when the model was cmplete, and i was too lazy to add it to each compnent (as you've seen they're quite a lot: the arches on the same stories seem to be identical, but in fact they are not, they have little differences).
                    so, could you explain me how you positioned the material on the arch? thanks in advance.
                      pichuneke
                      Gaieus gave me a good idea for my roman theatre with the textures.
                      Julius, with our models one day we will be able to do our own roman city! 💚
                        Julius
                        why not? 💚
                        • W Offline
                          watkins
                          Take a look at
                          Ancient Rome Rebuilt! Digitally
                          Rome's Mayor Walter Veltroni will officiate at the first public viewing of "Rome Reborn 1.0," a 10-year project based at the University of Virginia and begun at UCLA to use advanced technology to digitally rebuild ancient Rome. “Rome Reborn 1.0" shows almost the entire city within the 13-mile-long Aurelian Walls as it appeared in A.D. 320. At that time Rome was the
                          Science Codex (www.sciencecodex.com)
                            Julius
                            @watkins said:
                            Take a look at
                            the article is quite old, in the meantime the major has changed 😛
                            btw, it's an interesting project.
                              Hi Julius, with what I wrote "the positioning could have been nicer" I meant what I did. With more careful positioning I could have achieved better results.
                              As you asked for i9t, I will make a tutorial about how to do this positioning thing (although if I can find the one I remember, I may just link there).
                              Edit: I have found the tutorial:
                              http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=635&
                              M technique was somewhat similar - although since your arch here is not perfectly a half circle, I had to adjust each and every segment of it. As for rotating the material, read about "Manipulating a Material Using Fixed Pin Mode" in the SU Guide. You can use the green grip to rotate your texture about the red grip.
                                mcat
                                i love this roman aqueduct
                                my holiday photo:
                                http://www.panoramio.com/photo/3347979
                                http://www.panoramio.com/photo/3536096
                                http://www.panoramio.com/photo/3535761
                                Forgive my ponglish...
                                  Julius
                                  Thank you Gaieus! I attach an image of the first arch i've done: it was quite boring and i still have to do the other arches.
                                  http://img233.imageshack.us/img233/1184/pontdugardarchoq3.th.jpg
                                  my holiday photo:
                                  nice photos, i remember the olive tree! i think it comes from spain or something like that.
                                    Yes, Julius, certainly it is very boring but once you finish an arch, you may be able to use it as a component on arches of the same size and shape. And don't forget; texturing (especially if you want to render in an external application) is almost as important as modeling itself. 😉
                                      Julius
                                      that arch is a component: but there are 6 different kinds of arches in this model...
                                      you're right: in fact i exported the model to kerkythea and the texture on the arches was randomly placed! after all the time i spent positioning it! so i had to go back to SU, export a 2d view of the arch and import it as texture. and when i exported it to KT it was ok.
                                        Hm... There must be some problem then, during the export. It should not screww up the positioned textures! 😲
                                          GreyHead
                                          Most likely you need to select "Export default UVs" as 'Yes' when you export to Kerkythea from SketchUp. If the UVs aren't exported then KT uses settings of its own.
                                          The picture on the left has the default settings and some textures are large and others small. The one on the right uses the SU mapping (though some textures are missing in this case - it's the earlier version of he model posted below).
                                          Bob
                                            Julius
                                            Bob
                                            mmm...that doesn't seem to solve the problem, on the contrary...
                                            the attached image below shows the model exported in KT with UVs:
                                            http://img396.imageshack.us/img396/9346/withuvshz0.jpg
                                            • 1 / 3
