    Make line along a curved surface
    3 Posts 2 Posters 576 Views 2 Watching
      JimN
      I want to put a line along a curved surface where two objects intersect and then select and eliminate any part of the object that is above this curved line. Because this line is not along any particular axix and is curved in nature I am just having a difficult time trying to accomplish this. Any suggestions would be helpful? Jim
      • boofredlayB Offline
        boofredlay
        Select all your geometry, right click then choose Intersect - With Model (or selected)
        This will create your line and allow you to delete your unwanted geometry.
          JimN
          Eric: Perfect! I knew there was probably a solution I was overlooking. Intersect with Model worked nicely. Thanks Jim
