    Wrapping cut-out shape around a cylinder?
    5 Posts 2 Posters 2.1k Views 2 Watching
      gregv
      hello all
      first post here, wasn't sure if I should put this in the "newbie forum" or not.
      Anyways, I have a pattern akin to a cell structure that I have made as a flat shape in SketchUp, and I want to be able to wrap this shape onto a cylinder. This is for a film set design, and this cell-like pattern would be used as a horizontally-curved backdrop to a hi-tech lab set. It will end up with voids in it, so I can't really use an image and apply it as a texture.
      Besides cutting it into many facets and angling each, there must be a way (I hope) of simply wrapping the pattern onto the curved surface?
      Any assistance appreciated!
      cheers
      Greg V.
      Eureka
      • F Offline
        fbartels
        Hi gregv,
        You could take your shape, intersect it with a TIN surface, and then bend the TIN, section by section. It's a little tedious but you can do it quickly. Just took a couple of minutes to make the attached.
        Fred
        Untitled.skp
          gregv
          hello Fred
          that's very similar to what I have to make, thanks!
          Pardon my ignorance, though, but what is a TIN surface, and how would I bend it? Or does this mean that I would have to basically facet the flat pattern and rotate it piece by piece to match my desired radius? That was my last resort, I was hoping there was some magic "apply selection as surface" function or something....
          cheers!
          greg v.
          • F Offline
            fbartels
            greg,
            Take a look at SketchUp's Sandbox tools. A TIN is just a surface that is divided into lots of triangles.
            I don't know of any easier way to do this than by repeatedly selecting a section and rotating.
            Fred
              gregv
              Fred
              thanks, I delved into the SketchUp 5 book last night and read up on TINs etc; I have to admit to being a little shy of the Sandbox tools....
              thanks again!
              greg v.
