    Alternative modelling programs
    33 Posts 12 Posters 1.8k Views 12 Watching
      dylan
      Thanks for the info Lewis.
      Rhino is a program I have had in the back of my mind for a while now as one I would like to learn. I have noticed more Architectural Practices advertising for people with skills in Rhino.
      I shall go check out RhinoTV and see what it can do.
      http://dmdarchitecture.co.uk/
      • W Offline
        watkins
        Dear Lewis,
        Why were the McNeel reps so contemptuous about SpaceClaim? I am interested as I am about to be given a copy to try out (Pro version). I half expect to use it the way I use Sketchup, and then to export to Inventor 11 for final modelling and drafting. I have watched many of the tutorials and the program has the same feel to it as Sketchup with a minimum of tools.
        Any feedback would helpful.
        Regards,
        Bob
        • W Offline
          watkins
          Dear Lewis,
          Many thanks for the detailed reply. By the way, do you teach at a Higher Education Institute? If so, I suggest you contact your SpaceClaim rep and ask what the deal is for an educator. You might be pleasantly surprised.
          Kind regards,
          Bob
            lewiswadsworth
            @watkins said:
            Dear Lewis,
            Kind regards,
            Bob
            I believe they will just give me a license while I'm an instructor, Bob...but I will contact them and find out exactly what the mechanism for that is. Thanks.
            col sporcar si trova
              lewiswadsworth
              Bob,
              I met with the local rep just to get a sense of where the program was going before I taught the class, and I brought up Spaceclaim because it is a "local product" which makes much of its interchangeability with Rhino. And it really does work read and write 3DM files well. And it's about the least money you can spend on a BRep solid modeler.
              But the rep was utterly contemptuous..."Everything I could ever want to do with that program I could do faster with Rhino." That is hardly a statement I could challenge, but the odd issue is that Rhino is (even when it makes a "solid" object) really just making a closed NURBS polysurface, not a solid in the same sense as a BRep modeler (which is what Spaceclaim makes). There are some "solid editing tools" now available in Rhino, but for all but the most simple objects they tend to fail (it's apparently related to the old Boolean operations/trimmed NURBS surface limitations), requiring one to operate at the level of individual surfaces again.
              The rep is an industrial designer, not an engineer or an architect, so this may be simply his experience or his applications for modeling software.
              Right now, I'm a little more interested in MOI than Spaceclaim as a way of producing "swoopy" 3D things in a quick, intuitive fashion, but I'll probably eventually end up getting licenses to both. (I tend to get deals as an educator.) On the other hand, I've been using Rhino, by itself, for six years so I can generally get any shape I want with a minimum of fuss...
              Incidentally, in case you are wondering, the most astonishing development in the Rhino world I discovered during my meeting is not some secondary program but a beta plugin called
              "explicit history."
              http://en.wiki.mcneel.com/default.aspx/McNeel/ExplicitHistoryPluginMainPage.html
              Youtube:
              It's a visual, node-based scripting language!
              • W Offline
                watkins
                Dear Lewis.
                That is pretty much it. I was surprised when I found out. Like AutoDesk's Inventor package, I was expecting a good educational discount, but SpaceClaim has obviously decided to promote the software in schools and universities. A wise move as today's student is tomorrow's user and buyer.
                I will let you know how I get on when I have the software. I have too much to do at the moment and so I don't want to be distracted by something new. Sketchup is bad enough.
                Regards,
                Bob
                  PeterCharles
                  Solid modelling - Inventor 😐
                  Surface modelling - SketchUp Pro 😄
                  CAD - ChoiceCAD (16 bit UK version, available now as AllyCAD) This was my second CAD program, after X-CAD on my Amiga, and I still love it for quick 2D drawings. 😄
                    remus
                    Has anyone here tried silo? it looks quite interesting (and more importantly a bargain!)
                    link: http://www.nevercenter.com/
                      I just downloaded it. The interface looked very easy to get into. Very interesting modelling app.
                      Previously I've used Rhino. Think it was version 3, or 2, we used at uni. We used it mostly to create 3D working drawings of the models we made. (I did a modelmaking course)
                      Had a quick look at the Penguin render for it, but never really got into experimenting. Haven't tried v4. Is it much different from v3?
                        How about Flamingo or any of the other zoo animals?
                          lewiswadsworth
                          The new version of Flamingo is (or soon will be) the version of this
                          http://nxt.accurender.com/
                          for Rhino. (Accurender is another McNeel line.) I've downloaded the beta (or is it alpha?) but I haven't had a chance to play with it much. The built in Rhino Render has been improved so much that for many purposes it is almost enough, with a judicious addition of post-processing and some layering with Penguin, for my purposes.
                          • I Offline
                            ilay7k
                            Lewis, look at http://www.sketchucation.com/forums/scf/viewtopic.php?f=67&t=235
                            sketchup had it...mmm RPS
                              lewiswadsworth
                              I know...I have a beta copy for the upcoming SketchUp version.
                              • jujuJ Offline
                                juju
                                h8!!!
                                  lewiswadsworth
                                  h8!!!
                                  I beg your pardon, Julian...what does that mean? Here's the link...you just sign up and they give you download rights.
                                  http://nxt.accurender.com/files/folders/arnxt/entry1668.aspx
                                  Anyway, weren't we talking about other modelers?
                                    lewiswadsworth
                                    That really looks almost too good to be true for a mesh modeler. Something else to add to the list of things to play with...and just when I was happily settling down to play with my faculty license to MOI!
                                    Nevercenter is based in Salt Lake City...I've never heard of them or this product before. Has anyone here ever used it for anything?
                                    Thomas, most importantly Rhino 4 added 2D layout capabilities (something like ACAD's paperspace) so that you can use it as a full CAD solution without resorting to any plugins or other programs. I haven't had to upgrade my AutoCAD license since Rhino 4 came out...what a relief to tell those AutoDesk jerks what they can do with their extortion--I mean, subscription--packages!
                                    McNeel made a great deal of improvements to mesh and solids handling for Rhino 4, but I frankly have not found the changes affecting my workflow much.
                                    I do have the newer version of Penguin for Rhino, as well...I actually find Penguin a little buggy, but in general I can if necessary use it to produce decent NPR renderings.
                                      linea
                                      hmmm,
                                      Rhino 4 sounds interesting, I was using Rhino v2 years ago but I moved away from it and went through a naive snails-pace "Only Autodesk for everything" phase.
                                      Has anybody tried Wings 3d?, I downloaded it the other day, it's free, certainly simple to use and looks like it could be pretty useful.
                                      http://www.wings3d.com
                                      I really like the feel of MOI, the interface is great but I don't think it is that straightforward to use.
                                      Remus originally wrote
                                      Id really like to find soemthing thats better for producign plans than SU and layout.
                                      I am constantly hunting the evolutionary missing link - a 2d cad handshake with Sketchup. It pains me to say it but I still think AutoCAD or a flavour of Intellicad (such as ProgeCAD) are hard to beat for this. I tried Spirit but I didn't understand it at all.
                                        I'm interested in a package that'll be suited for landscape. I some times get projects where there's allot of landscape, large terrain and vegetation. And that makes SU choke just thinking of it.
                                        • I Offline
                                          ilay7k
                                          ...vue inf/xstream....
                                          and add-ons to other modeling programms like d.p.i.t. for cinema4d, tgen for xsi and ect...
                                          • jujuJ Offline
                                            juju
                                            h8!!!
                                            OK, I misunderstood you somehow. I thought you had a beta release of SU7.
                                            • 2 / 2
