Print only desired area??
How to print desired area? Is there a way to select a fix area before printing?
Please advice. Thanks
Pankaj -
SU always prints the area your currently looking at, so if you want to print a specific bit just look at it and it should come out of the printer as your looking at it on the screen.
Another way to do it would be by exporting 2d images, and the printing the iamges. This will give you more control over the final image. To do this, look at the bit you want to print, the go file->export->2d image, and select the destination.
that will help. tx
