@Rich-O-Brien Well done guys.
Global Moderators
Forum wide moderators
RE: [Plugin] Axyz - v1.0a - 31 May 24
Axyz is a joint project between myself and @fredo6
RE: D5 Render Work
@marked001 That's impressive. Is it real-time? The glass reflections are well done if it is real-time.
Looks like your pushing the engine a fair bit. There's weird little glitches like the screen space reflections can't keep up with the camera and the light passing through the ceiling lats.
Definitely sells the space though. Except for the cheapskate out on the balcony having 2 bananas.
RE: [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
@raptorscream Hi, this is a normal behaviour for RoundCorner in some circumstances. For example when you bevel coplanar edges that are a closed loop or part of it. I guess because the plugin somehow "erases" and then "draws" again some lines in the process. This causes Sketchup to automatically generate a face.
Just select and delete the unwanted surface. -
Further Information and usage instructions on Axyz is available here
Requirements
- LibFredo6: v14.5 or above Download Libfredo
- Sketchucation Tools v4.4.1 or above Download Sketchucation Tools
- SketchUp 2017 and above
- Licensed under Sketchucation SCFLicense (Free)
Overview
Perform transformation on selected objects with a Widget: Translation, Rotation, Scaling, Mirror
- Manipulates Guides, Edges, Faces, Images, Groups and Components
- Position Widget in the model by a simple Click or inferencing
- Transformation (translation, rotation, scaling, mirror) by Click-Drag on a widget handles
- Post-transformation adjustments via VCB and modifiers (copy and multiples, distance, angle, scale factors)
Help is integrated in the extension, as a Quick Card.
Link to YouTube Playlist
Keybindings
TAB to cycle transformations
ALT to cycle global, local or current context axes
SHIFT to cycle individual centers
CTRL to cycle copy mode
ARROW to cycle nudge modeHave fun!
RE: TIG Text tag tool
I made some tweaks and now it works almost too fast in newer SketchUp versions !
But in v2017 it is still quite slow...I'll sleep on it and look at again tomorrow...
It's been 11 years since I wrote it.
As far as I know it works with all SketchUp versions currently available.
I've had no reports of issues with v2017.
However, I just tried it in v2017 and it was very slow and eventually SketchUp quit, with no error messages.I'll look at it but I can't promise a fix, it is v-e-r-y old...
Just adding @TIG so he sees the thread
RE: How do I use follow me tool when the lines split?
It depends on what you want in the corners. If you don't need something too polished you can also use this plugin:
https://community.sketchucation.com/topic/106330/plugin-lines-to-tubes#p88592
It will work in one go: select all the lines and launch the plugin.
