    Select All Surfaces in a Model? Need assistance.
    10 Posts 3 Posters 1.6k Views 3 Watching
    • JClementsJ Offline
      JClements
      I have a project in which I will be exporting my 3D model to AutoCAD. I am using the 3D export option because it maintains components (as blocks), circles, arcs, dimensions, leaders, layers, and editable text.
      However, "Faces in SketchUp are exported as a triangulated polyface meshwith interior splframe hidden lines (if applicable). This conversion helps to simulate the appearance of your native SketchUp file, even when all exported faces are triangular".
      I would like to export just the edge-entities, not the faces. Does someone have a script the will dig down through the entire model (into all nested entities), select the faces, and delete the faces (so they can't be exported).
      My methodology would be to: save the SU model, run the script, export the 3D model, and then either do a Restore or an Undo.
      • G Offline
        gksl4
        There is a ruby script desel.rb at http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_sel_page.htm
        thanks to TBD
        • fredo6F Offline
          fredo6
          Here is a simple code to select all faces at the model level
          def select_all_faces
                  model = Sketchup.active_model
                  model.selection.clear	#empty the current selection
                  model.entities.each { |e| model.selection.add e if e.typename == 'Face' }
          Note that you cannot select entities at different levels, for instance in the first level of the model and at the same time within groups or component instances
            JClements
            Fredo,
            then could the above be adapted to select all faces on the upper level, delete those faces and then edit each entity in the next level of nested entities, select and delete their faces, and then to the next level of nested entities and so on?
            • fredo6F Offline
              fredo6
              If you need to earse all faces at all levels, then you must do it differently
              Here is a code sample
              def process_faces
              	model.start_operation "erase all faces"
              	process_faces_at_level model, {}
              	model.commit_operation
              def process_faces_at_level(grp, hcomp)
              	list_entities = []
              	grp.entities.each do |entity|
              		case entity.typename
              		when 'Group'
              			process_faces_at_level entity, hcomp
              		when 'ComponentInstance'
                                      edef = entity.definition
              			next if hcomp[edef.to_s]
              			hcomp[edef] = edef
              			process_faces_at_level edef, hcomp
              		when 'Face'
              			list_entities.push entity  # store faces in the list
              	grp.entities.erase_entities list_entities #or do what you want with the faces
              Note the specific treatment of component instances, as you must delete the face only once in its definition (which will propagate then to all instances)
                JClements
                Fred:
                Thank you for the code. Not only did it work, but it seemed to do so fast. :}
                One more request.
                In some models, I will want to retain the faces of any smoothed surfaces (such as those made via Push-Pull, Follow-Me, or manually softed) so I believe any Softened or Smoothed edges would have to be Unsoftened and Unsmoothed first before finding and deleting faces.
                Can you add code for an option to do this?
                • fredo6F Offline
                  fredo6
                  I am not clear on what you want.
                  Do you want to keep faces which have at least one edge smoothend or softened?
                  Or do you want to change the property of these edges, and still erase all faces?
                  • fredo6F Offline
                    fredo6
                    Then you need to add one line of code (in the When 'Face' section)to change the "soft" property of the edges bording the faces. This slows down the script a little bit, but I undersatnd why you need it.
                    def process_faces
                    	list_entities = []
                    		when 'Group'
                    			hcomp[edef.to_s] = edef
                    		when 'Face'
                    			list_entities.push entity  # or do what you want with the face
                    			entity.edges.each { |e| e.soft = false } #Keep smooth edges
                      JClements
                      Fred:
                      Worked again. Many thanks.
                      John
                        JClements
                        Change the property of these edges so that when their respective faces are delected, the edges remain.
