π¨ Skimp | 25% Off until March 30 Buy Now
Licence should be seperate
Layout is coupled with Sketchup in reading the licence file.
So if I try to start Layout as seperate Application, Layout tells me `missing file/Sketchup6.lf.
I would like to see Layout as an external application, reading the licence fileBurkhard
Strange, I do not get that error when I start up LO without having SU6 running. Are you sure your SU6 installation is fine?
I don't have that problem either. Actually never had any problem with licensing ever since I purchased the license.
sure you don`t have, because I try to make my Sketchup portable
The licence and the seperate Net Framwork installation
are the main obstacles to do that. -
OK
