    Initiating Sketchyphysics causes Bugsplat
    9 Posts 2 Posters 6.5k Views 2 Watching
      LOAFIN ANDY
      Every time I initiate Sketchyphysics to play even a simple cog set up SU crashes and Bugsplats me. Any ideas as to what may be causing it. I've tried reinstalling it and it is the latest update, so I'm stumpped.
        CPhillips
        Hmm. Does even a model with just a shape or two crash? Or is it just when using joints?
        Chris
          LOAFIN ANDY
          I can create just a box with a slider, or cogs with 2 spinning joints, very simple models, but as soon as hit play it crashes every time.
          Could anyother plugins be causing a conflict perhaps? ❓
            CPhillips
            If you are not using joints right it could cause a crash. Does a model without joints cause a bugsplat?
              LOAFIN ANDY
              No crashes without joints, but I have tested with some simple models from the warehouse and get splatted each time?
                CPhillips
                Very interesting.
                First make sure you are using the right version. It should be the one from this page: http://code.google.com/p/sketchyphysics/downloads/list Dated July 7.
                Another possiblility, Are you loading the 3dwarehouse models directly into Sketchup via "File->3dwarehouse->Get Models". If so that might be the problem. Try downloading the files with a browser and then open in Sketchup.
                If that is not the problem then I dunno... Whats your OS? Videocard? Do you have Sketchup installed in an unusual location.
                Chris
                  LOAFIN ANDY
                  Running with Windows, with a Quadro FX 1500 graphics card and with SU in standard Program files and running the current version of Sketchyphysics. Tried both directly downloading into SU and loading from saved file both with the same result 😒
                    CPhillips
                    Boy, I don't get that. It should all work or none of it. Could you post a model that causes a bugsplat. I'll try it on my machine.
                    Chris
                      CPhillips
                      Also a copy of the bugsplat data might be informative.
                      Chris
