    Wine Decanter
    6 Posts 2 Posters 1.7k Views 2 Watching
      Baker518
      Let me know what you think please
      Don't worry about things you have no control over. Worry is a lack of Faith!
      • EdsonE Offline
        Edson
        mike,
        it looks good but there is room for improvement. unless you want it to look faceted your curves could have more segments to them. the handle is one region where you perceive the curve is made up by linear segments.
        also, you should update your scenes. the only one that shows anything is the front elevation. the other ones show the object so far away that it is impossible to see it.
        http://www.mahfuz.arq.br
          Baker518
          Thanks for your comments, I went back and updated the scenes, but I dont know how to change the segments other than redo it all together.
          Wine Decanter.skp
          • EdsonE Offline
            Edson
            i am not sure you can increase the number of segments when the model is so advanced as yours is. perhaps some of our SU veterans can tell us that.
            but you sure can at the start: when you select the circle tool the VCB (lower right hand corner of the screen) informs you the current number of sides. you can change it before you tell SU the radius/diameter.
              Baker518
              Edson,
              I went back and redrew it after your suggestion. I set the number of segments to 90 just to see and you were absolutely correct. It was much smoother, and thanks.
              • EdsonE Offline
                Edson
                i am glad i could be of help.
