    Using default sketchup materials with Ruby API
    4 Posts 4 Posters 2.1k Views 4 Watching
    • M
      mocathe1st
      I think I'm missing something in the docs, but can anyone tell me how to assign default sketchup materials to faces? The docs seem to be for Sketchup 4 and talks about .jpg files.
      I tried the following code but it just changes the material to black:
      materials = Sketchup.active_model.materials
      m = materials.add "opening"
      m.texture="c;\\Program Files\\@Last Software\\Google SketchUp 6\\Materials\\Translucent\\Translucent_Glass_Sky_Reflection.skm"
      face.material = m
      Any help would be great.
      Thanks.
      • R
        RickW
        Do you really have GSU6 installed under "@Last Software" ??
        That would be my first guess.
        RickW
        www.smustard.com
        • C
          CPhillips
          I dont know if this is your problem or not but...
          I found a bug a while back where if I tried to apply a material with a texture that wasn't already in the model it would to unpredictable things including crash. Try adding that material to something by hand before you try to assign in using ruby.
          Chris
          > face.material = m
          Thanks.
          • S
            shneidor
            This code works for me:
            model = Sketchup.active_model
            materials=model.materials
            Adds a material as an in model material
            m = materials.add "Test Color"
            begin
            Returns nil if not successful, path if successful
            path=Sketchup.find_support_file "1.jpg","\Plugins\"
            # m.texture = "1.jpg"
            m.texture = path
            m.texture.size = 666
            rescue
            UI.messagebox $!.message
