    Keeping control over very long tasks
    2 Posts 2 Posters 832 Views 2 Watching
    • fredo6F
      fredo6
      Hi to all,
      I was wondering if there was a way to give back control to the Tool message loop when performing a long calculations.
      To be clearer let's assume you have a piece of code that may take a long while to process. Assuming it is executed in the context of a Tool, it seems that you cannot catch any event while it is processed (such as getting a key or click down). This may be because Sketchup is monothreaded.
      I tried to call iteratively each piece of processing in a Start_timer call, but this does not work (in addition the usage of Ruby continuation, callcc, does crash the program).
      If you start a seaparet thread, it does not work either (it seems that Skecthup API cannot eb executed ina separated thread).
      If anyone has an idea, that would be helpful. It is a pity that Sketchup does not have a method for that!
      Fredo
      • AdamBA
        AdamB
        I've had no success either. I guess its because if you look at how its recommended to embed Ruby in an App, its a very simple ruby_run() model. So SU may be multi-threaded or not, but the call to Ruby is a busy wait.
        Pretty much the only thing that does work is spawn a Ruby thread that twiddles the Sketchup.set_status_text
        Adam
