    Yafray Render
    33 Posts 7 Posters 7.0k Views 7 Watching
    • david57D
      david57
      Here's a render from yafray. Modeled with SKECTCHUP. The model was
      exported into blender with the use of this script.
      http://shaxam.com/files/lwo_export-0.0.6.zip
      The quality of the render is low, because my computer is old.
      I did other renderings with a different engine. Named Yaf(A)ray.
      http://www.yafray.org/forum/viewtopic.php?t=976&postdays=0&postorder=asc&start=270
      and here.
      http://www.yafray.org/forum/viewtopic.php?t=976&postdays=0&postorder=asc&start=315
      • david57D
        david57
        Here's another.
        • david57D
          david57
          • david57D
            david57
            Thinking of placing a hip roof to the entry, I don't like the gable, it looks
            like a dog house.
            • GaieusG
              David,
              I really like these renders though the walls look somewhat "artificial" still.
              I've seen some very interesting ones on the site you provided the link to.
              And I definitely like the roof. It's just perfect.
              • david57D
                david57
                More.
                http://www.yafray.org/forum/viewtopic.php?t=1410
                • david57D
                  david57
                  Here's a 13 minute render. Planning to place a garage to the far right.
                  • david57D
                    david57
                    But, before i built the garage, i need VEHICALS.
                    • david57D
                      david57
                      Something strange happened to this render. It's not posible.
                      • GaieusG
                        It must be waaay down in the south as it seems to be summer there...
                        πŸ˜’
                        • S
                          SpaceCow
                          Hey guys,
                          I'm new to the SketchUp forum and wanted to export a sketchup file to blender because I love to use blender as well. I downloaded the .lwo exporter and blender won't open it. Is it supposed to? I thought blender was only supposed to open .blend files and such.
                          if there is an exporter from sketchup to blender and someone could help me it would be much appreciated.
                          • david57D
                            david57
                            Ok SpaceCow, try to import the lwo as in the image below.
                            • david57D
                              david57
                              My sun energy is set to 1.0 the default. Yafray settings for the most
                              recent renders are below.
                              • david57D
                                david57
                                And don't forget the sky color. No HDR's. This settings should work for any
                                exteriors.
                                • S
                                  SpaceCow
                                  Thanks dave!!!!
                                  • david57D
                                    david57
                                    • david57D
                                      david57
                                      Trying out some lanterns from Google 3D Warehouse. Modified a bit.
                                      Needs white frosted glass.
                                      • GaieusG
                                        Could you use some bumpmaps on those walls? They are great but that would spice up the whole picture big time!
                                        • soloS
                                          solo
                                          Coming along great, some ground textures would make it 'POP' nicely.
                                          http://www.solos-art.com
                                          • david57D
                                            david57
                                            More bump to walls and floor. Slows processor legs to a crawl. Might need a larger
                                            cement slab and door.
                                            • 1 / 2
