    Tileable stone.
    10 Posts 5 Posters 5.6k Views 5 Watching
    • boofredlayB Offline
      boofredlay
      I need a texture very similar to these pictures that is tileable.
      http://www.sketchucation.com/forums/scf/sas/Materials/StoneTile1.jpg
      http://www.sketchucation.com/forums/scf/sas/Materials/StoneTile2.jpg
        sorgesu
        Eric I've posted a good selection of them for you on Kelly's site.
        Download Here
        This one is quite nice but you might need to adjust the hue a bit.
        http://www.sketchucation.com/forums/scf/sas/Materials/Stone Tileable/csv2040t.jpg
        Susan Sorger
          boofredlay
          Susan, thank you very much. However I need one to be quite a bit closer to the images I posted. Notice all the small stones "wedged" between the larger ones.
          I am looking all over the texture resources that was posted here in the MCS.
          Thanks again Susan, I have saved these for later use. 😎
            tomsdesk
            Eric, went to the tut forum to see if I had time this morning to play with RobM's "Tileable Textures" (the do it for me in PSP didn't do well, sorry)...but the how-to attachment was missing???
            If you find that, try that...then post it back in Rob's tut please πŸ˜„
            Best, Tom.
            2.5D Trees & Shrubs!
              boofredlay
              Well I just talked with the PM again and he said we were going to go with a manufactured stone and not to worry about finding a texture with the small stones between. So I think I can use one of Susan's.
              Thanks both of you. πŸ˜„
              • KrisidiousK Offline
                Krisidious
                stonecad Boo
                By: Kristoff Rand
                • Mike LuceyM Offline
                  Mike Lucey
                  That's going to be a tough one Boo.
                  The little stones are called 'snecks'
                  in dry walling and they are very common
                  here in Ireland.
                  Have you thought about having a go with
                  PS?
                  Here are a couple of links that might cast
                  some light for you.
                  The second one seems to be very good and
                  possibly worth the effort.
                  http://www.highpoly3d.com/writer/tutorials/tileable/seamless.htm
                  (www.gfxartist.com)
                  Mike
                    boofredlay
                    Thanks Mike, I will check them out in due time.
                      Mike Lucey
                      Eric,
                      Your problem must have been one those things that lodged
                      in my brain over night.
                      Anyway, this morning it just dawned on me that one way
                      to create something that might suit you would be to take
                      an existing tilable texture and edit it, placing the
                      snecks (small stones) here and there also 'blackening'the
                      pointing (joints) to give the effect of a dry rubble stone
                      wall.
                      Hope this helps.
                      Mike
                        boofredlay
                        That is one of those "Duah" moments because when I read what you wrote above I went "Duah". Wish I had thought of that.
                        Thanks Mike.
