    Boxes and Component Size
    2 Posts 2 Posters 1.3k Views 2 Watching
    • A
      agrazdi
      1 - Is there a ruby that can be added to the BOX.rb and be able to select the initial point < like you do with the wall ruby > ?? instead of the origin or an x,y,z coordenates?
      2 - Last one, is there a way to get with a Ruby the size of groups and components ?
      Thanks in advance
      agraz
      http://www.sketchucation.com/forums/scf/sas/Ruby/BOX.jpg
      • J
        Jim
        Thanks in advance
        agraz
        Yes, it's possible.
        1. Look into using a PickHelper or a InputPoint object to select the initial point.
        2. It depends on what you mean by "size"? Look up the bounds method for Groups and Components. A BoundingBox is a 3D box aligned to the global axis, and includes all the entities inside the Group.
