Boxes and Component Size
1 - Is there a ruby that can be added to the BOX.rb and be able to select the initial point < like you do with the wall ruby > ?? instead of the origin or an x,y,z coordenates?
2 - Last one, is there a way to get with a Ruby the size of groups and components ?
Thanks in advance
agraz
Thanks in advance
agraz
Yes, it's possible.
Look into using a PickHelper or a InputPoint object to select the initial point.
It depends on what you mean by "size"? Look up the bounds method for Groups and Components. A BoundingBox is a 3D box aligned to the global axis, and includes all the entities inside the Group.
