    ShrinkWrap
    9 Posts 6 Posters 2.9k Views 6 Watching
    • KrisidiousK Offline
      Krisidious
      can I have a shrinkwrap script to make a shell out of any detailed model I have?
      By: Kristoff Rand
        RickW
        I don't have any objections 😉
        RickW
        www.smustard.com
        • jujuJ Offline
          juju
          sounds kinda sweet. looking forward to it then.
            CPhillips
            If you are asking because of SketchyPhysics you dont need it. The physics engine will turn a mesh into a convex hull. Or if you really do want the shrinkwrap you could use still SketchyP. Set the meshes shape to convex hull and use the Debug->Readback collision geometry option. That will create a wireframe shrinkwrap of the mesh.
            Chris
              Krisidious
              what I want is a simple way to take a complex house model and make a shell that I can build many of in a development.
              or a complex car made into a simple car.
              By: Kristoff Rand
                CPhillips
                Ah. Nevermind then. 😄 That sounds hard to do.
                Chris
                  Krisidious
                  I think a ray cast script would do it...
                  pick a point inside the model.
                  cast rays in every direction.
                  everything but the farthest point is deleted.
                  after an intersection command and an explode command
                  By: Kristoff Rand
                    AcesHigh
                    That would be really interesting. There are many good uses to such script.
                    [AcesHigh]
                    • K Offline
                      kwistenbiebel
                      I haven't tested the option yet, but the SU2Fryrender has a function like that to get their instancing going.
                      It's not exactly the same but the complex component gets substituted by a low poly version so SU doens't choke on it.
                      At render export it will render the Hi poly version
