    Adjustable Line Widths aka Fat Lines
    15 Posts 5 Posters 2.4k Views 5 Watching
      todd burch
      I can produce fat lines around geometry with a script. Just select all the faces for which you want a fat edges, and run the tool. No big deal, really.
      Now, they won't File>Print, and they won't come out when exporting to a 2D graphic or PDF. However, on Windows, ALT+Print Screen works, and APPLE+SHIFT+3 or 4 works on the Mac.
      Any need for such a limited use feature?
      A sample comparison is attached. Typical lines on the left (unaltered). It's probably 5 pixels wide, whereas the typical exterior edge is 2 pixels.
      Todd
      http://www.sketchucation.com/forums/scf/sas/Ruby/Picture 15.png
      • boofredlayB Offline
        boofredlay
        Seeing as how it would not export as an image this limits it quite a bit. However for on screen visualization... I would not mind having it.
        • monsterzeroM Offline
          monsterzero
          Todd, I would love to use something like this but as Eric mentions, it's pretty much useless to me if it can't export.
          [monsterzero]
          monsterzero
          My New Twitch Stream!
          https://www.twitch.tv/infinitestorylab
          infinitemachine.com
            todd burch
            It does kinda add a lot of emphasis if you want to bring attention to soemthing.
            Todd
            http://www.sketchucation.com/forums/scf/sas/Ruby/Picture 16.png
              boofredlay
              That is neat πŸ˜„
                todd burch
                By the way, I have the script set up to increase the line thickness by 1 pixel each time the left mouse button is clicked. It appears the max thickness is somewhere between 30 and 35 pixels, which is pretty wide... too wide.
                Right now, the wider the lines get, the more the endpoints don't match up - but that could be compensated for.
                Also, you get your choice of line color (limited) and pattern (also limited). πŸ˜„
                Here's the same box with a hairy green outline.
                Todd
                http://www.sketchucation.com/forums/scf/sas/Ruby/Picture 17.png
                  todd burch
                  It's the PURPLE MONSTER!!
                  http://www.sketchucation.com/forums/scf/sas/Ruby/Picture17.png
                    todd burch
                    Same purple box with a solid line. Note the corners. Yuk.
                    http://www.sketchucation.com/forums/scf/sas/Ruby/Picture 18.png
                    • Mike LuceyM Offline
                      Mike Lucey
                      Well done Todd, I think a script to do this
                      would be very usefull. In my case I could
                      use it via a Screen Shot into Canvas. When
                      in there I simply resize to scale, it works!
                      Some 'hairy purple / green' drawings might
                      have there uses πŸ˜‰
                      Mike
                        monsterzero
                        Wow, Todd. That is soooo cool. Is there a way that thickness can be "styled"?
                        [monsterzero]
                        monsterzero
                        infinitemachine.com
                          todd burch
                          Justin, give me an example of what you mean by "styled." I suspect not, other than a few patterns and several colors (actually, I might be able to get any SU named color).
                          I think I can randomize the pattern, color and thickness all in the same view, which might end up pretty crazy looking.
                          If you think of the protractor tool and the rotate tool - I can do the same things with pretty much any pattern. A thought cloud could be drawn, or a light bulb with the circular array of light-rays.
                          Todd
                            Speaking of other uses - the green hairy style just gives me the idea of creating grass with it.
                            Would it work witth hidden lines, too?
                              todd burch
                              Gai, it will work with whatever I tell it to work with! LOL!
                                Cool - just I give a fairly dense grid of lines and there is the "virtual" grass.
                                πŸ˜„
                                  todd burch
                                  Here's some virtual "grass" on top of the grass texture. 😐
                                  Todd
                                  http://www.sketchucation.com/forums/scf/sas/Ruby/Picture 19.png
