    Organizer.rb error on sketchupConnector.dll
    7 Posts 2 Posters 1.6k Views 2 Watching
    • KrisidiousK
      Krisidious
      Error Loading File organizer.rb
      126: The specified module could not be found. - C:/Program Files/Google/Google SketchUp 6/Plugins/sketchupConnector.dll
      any help?
      the file is located in the correct folder.
      By: Kristoff Rand
      • R
        RickW
        What file is requiring the .dll? Is it in a subfolder?
        RickW
        www.smustard.com
        • KrisidiousK
          Krisidious
          no it's right there in the folder it's looking for it in.
          By: Kristoff Rand
          • R
            RickW
            That was two separate questions 😉
            Generally, required files must be in the Plugins folder, even if the file doing the requiring is "organized". This can be changed in one of two ways:
            1. hardcode a relative path in the "require" line. Ex:
              require "./mysubfolder/filename.rb"
            2. softcode a relative path in the "require" line. Ex:
              path = File.dirname(FILE).split("/").last
              require "./#{path}/filename.rb"
            I thought about including this in the rewriting portion of the plugin, but decided against it because of the abundance of 'require "sketchup.rb"' and similar lines that shouldn't be changed at all. True, those can be filtered out, but I decided against it for now. I may change my mind later 😄
            I'm almost done reworking the separate Organizer files into a class contained in one file. It also adds a "test" method to verify where required files should be located.
            RickW
            www.smustard.com
            • KrisidiousK
              Krisidious
              I would assume it's the organizer looking for it. but maybe not... I'm not familiar with connector.
              By: Kristoff Rand
              • R
                RickW
                I'll send you the troubleshooting file. It will read the scripts, find the dependencies, and provide a list of files that should be relocated.
                RickW
                www.smustard.com
                • KrisidiousK
                  Krisidious
                  you're awesome... that trouble script is the foshizzle
                  By: Kristoff Rand
