    Sketchup.active_model.layers returns <Deleted Entity>?
    7 Posts 3 Posters 4.0k Views 3 Watching
      Jim
      I'm not sure how I did it, but calling:
      #<Deleted Entity;0xb016af8>
      I go to the Layers dialog, add some new layers - same thing. File > New == same thing.
      How in the world can the layers object become deleted, and can I do anything about it from ruby? Shouldn't it at least always contain Layer0, since it is always present?
      Thanks.
      • KrisidiousK Offline
        Krisidious
        what ever that sound is when you run your fingers up and down over your lips?
        blblblbblblblb....
        cuz I ain't got no clue whatcha talkin bout george....
        By: Kristoff Rand
          RickW
          You can get the same thing with Sketchup.active_model.pages
          The problem usually occurs when something is assigned to a variable (ie pages=Sketchup.active_model.pages), the script is loaded (say, on SU startup), and then you start/open a new model. pages was defined with the original model, and doesn't get redefined to the new model.
          I've mentioned this to the SU crew regarding pages. I can add that you've had the same problem with layers
          RickW
          [www.smustard.com](http://www.smustard.com)
            Jim
            On a related issue, it doesn't look like a layer's page_behavior is saved with the model.
            Sketchup.send_action("showRubyPanel;")
            UI.menu.add_item("Layers y Pages") {
               layer = Sketchup.active_model.layers.add Sketchup.active_model.layers.unique_name
               layer.page_behavior = (LAYER_HIDDEN_BY_DEFAULT|LAYER_IS_HIDDEN_ON_NEW_PAGES)
               #layer.page_behavior = LAYER_IS_HIDDEN_ON_NEW_PAGES
               #layer.page_behavior = LAYER_HIDDEN_BY_DEFAULT
               page = Sketchup.active_model.pages.add
            UI.menu.add_item("layer behavior") {
               puts "=" * 25
               Sketchup.active_model.layers.each { |layer|
                 puts layer.page_behavior
            I've mentioned this to the SU crew regarding pages. I can add that you've had the same problem with layers.
              RickW
              Just tried this with FlightPath (which uses LAYER_IS_HIDDEN_ON_NEW_PAGES) and it worked fine. I saved the model, started a new model, then re-opened the saved model and checked the layer.page_behavior. Everything was saved with the model.
              RickW
                Jim
                It doesn't work for my posted example. Did I do something wrong?
                  RickW
                  I tried your example script, and see the problem you see.
                  According to the SU ruby docs:
                  "Currently there are two behaviors defined.
                  A page keeps a list of layers that do not have their default behavior. If a layer is not in that list, then it is set to its default visibility determined by one of these flags.
                  LAYER_VISIBLE_BY_DEFAULT 0x0000
                  LAYER_HIDDEN_BY_DEFAULT 0x0001"
                  The strange thing is that in commenting out different lines and trying the script again, LAYER_IS_HIDDEN_ON_NEW_PAGES is the setting that sticks - not LAYER_IS_HIDDEN_BY_DEFAULT.
                  I'll report that to the SU crew.
                  RickW
