    Saved file does not match what's on the screen.
    3 Posts 3 Posters 3.9k Views 3 Watching
    • daikuD Offline
      daiku
      I've got a situation where I manipulate comp instances through a series of transforms. There are several sub-comps within a parent comp. When all the dust settles, my new creation appears on the screen, and it looks correct. The script then opens the save dialog, and the user saves the file. If I then come back and open the saved file, it does not match what was on the screen when I saved it! Some of the sub-components have undergone some strange transforms, and appear flipped and located on the opposite side of the parent comp. Anybody seen anything like this? This doesn't happen every time, only with certain sitiations. But it's absolutely repeatable. CB.
      Clark Bremer
      http://www.northernlightstimberframing.com
      • KrisidiousK Offline
        Krisidious
        you need to explode it I think and resave as comp. to get the effect. I beleive the transofrm on components is on a per model scale. so when the component is added to the next model it's back to original size... right?
        By: Kristoff Rand
          RickW
          I could take a look - contact me through Smustard.
          RickW
          [www.smustard.com](http://www.smustard.com)
