Layout
Hi all,
I have to say I have been blown away with SU & it keeps getting better.
I do however have a small problem with Layout (I know it is still Beta) but when I try to save a drawing A1 as a pdf it is always blank, is there a work around or is this to be fixed. -
What is on the page? Just an SU model, or is there some text or other items?
Is there a red X? What version are you using?
If you just have a SU model, your only option right now is to reduce the
dpi until the model shows up. -
Sorry for the delay, been mad busy.
When i save/export my A1 drawing as a pdf no matter what DPI i use, it saves as a PDF file @ 4kb & when i try to open it it says error opening document, the file is damaged & could not be repaired.
Now do the same with an A3 drawing & I have no problem at all. -
@cannon5598 said:
Hi all,
I do however have a small problem with Layout (I know it is still Beta) but when I try to save a drawing A1 as a pdf it is always blank, is there a work around or is this to be fixed.Try LO 2 and see if its working now. It has much better handling of large page sizes now.
It even has multi-core support. (Win only for now)
Register LoginAdvertisement
