    How to animate a sliding door
    28 Posts 10 Posters 14.7k Views 10 Watching
      I mean long and tedious in SU
      ๐Ÿ˜†
      Here the bike animation, but alas the cool script "Transformer" by Didier Bur can't run in the same time that the classic animation of the sliding door by Martin ๐Ÿ˜’
      http://www.divshare.com/download/3597974-da2
      unzip and open the file Bike.htm in you favorite navigator
      (firefox is best)
      Ps In this case of this bike animation by the script how can I render this animation in Kerkythea?
        Ok that work!
        problem was the unities 50 and 20
        I have the french version it's write by default Step = 10 and Duration (second) = 5
        I input 2 seconds because I was speedy
        With that I just 2 draws Start / End ๐Ÿ˜ฎ
        With your numbers I have an animation (Miraculous) ๐Ÿ˜ but not during 20 seconds but seems 2 seconds ๐Ÿ˜„
        And it's an animation at the "screen" not in 50 pages !
        Have you some light about that?
        • GaieusG
          Well, if it went by the "classical" page (scene) transition, you could for sure.
          I don't know (but doubt) if/that you can render this in Kerky though.
            So wait someone transpose Script "Transformer" animation to page ๐Ÿ˜„
            • W
              watkins
              Dear Fletch,
              I am curious, and would like to know which bit of the message tickled you the most? Was it that 'an-already-overloaded-Didier' might have time to revise one of his old scripts? The last time I suggested a revision Didier did a superb job revising his Projections scripts. I have found the Transformer script useful from time to time, and simple to use, although I suppose I should try running SketchyPhysics with its many features.
              Kind regards,
              Bob
              • FletchF
                Fletch
                @formalyknownasmartin said:
                Hi Pilou,
                you canยดt push or move this bike using the section cut method.
                But you can beam it up. ๐Ÿ˜‰
                This is the skp-file:
                http://www.sketchucation.com/forums/scf/sas/Tutorials/beamingyourbike.skp
                Flash:
                http://www.sketchucation.com/forums/scf/sas/Tutorials/beamingyourbike.html
                F.K.A.M.,
                ๐Ÿคฃ ๐Ÿคฃ ๐Ÿคฃ
                that is one of the hardest laughs I've had on this forum in the longest time. THANKS!
                Fletch
                3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                • FletchF
                  Fletch
                  ๐Ÿ˜’
                  SORRY, I gotta stop posting so late at night... accidentally quoted the wrong text... fixed it now.
                  Fletch
                  • FormalyKnownAsMartinF
                    Hi Pilou,
                    beamingyourbike.skp
                    Flash-Animation
                    Martin Habes
                    • 2 / 2
