    Sketchy Physics Contest
    33 Posts 11 Posters 8.4k Views 11 Watching
      architectboy
      Here's a cool project, make a bridge. So for the competition we make supports that keep the roadway in the attached model up while the car drives over it.
      Rules:
      #1 Your bridge may only touch ground on the concrete abutments.
      #2 Your bridge must successfully carry the car to the other side (duh).
      #3 No using static or frozen parts.
      #4 No doing major (large scale) grouping, highly grouped joint pieces are allowed thou.
      #5 You may use as many joints as you want.
      #6 You must have "Sketchy Physics" and know how to use it to participate (another duh).
      #7 You may make minor additions to the abutments.
      Just post your finished bridge model here and rate everyone else's, the one people like the best wins!
      SketchyPhysicsBridge.skp
      • KrisidiousK Offline
        Krisidious
        more like a traffic accident there... Architectboy... the bridge fell apart when I started the engine... was that intended to scare me?
        By: Kristoff Rand
          architectboy
          No, you don't need to be scared, you're supposed to fix that and make it a working bridge. Like this one. And I'll add another rule to the list #7 You may make minor additions to the abutments.
          ArchitectBoyBridge.skp
            Krisidious
            lol well your trick worked that's what I'm doing...
            By: Kristoff Rand
              architectboy
              Ok, so I'm playing around with my bridge destroying it, throwing the car around, etc. when I come up with the idea of rendering the bridge, and once I had a nice render of it I couldn't help but make one of it destroyed πŸ˜„
                Krisidious
                awesome... love the blank color... deep shadow... and destruction, soon, you could render it in destruction...
                By: Kristoff Rand
                  architectboy
                  So you want one of it in destruction, or while it's falling, well here it is. And I don't want my bridge to be the only one up here, so someone make another one please.
                    CPhillips
                    That is amazing! Very nice construction ArchitectBoy.
                    I was going to do a arch bridge but yours is better. Maybe I'll try a trestle bridge.
                      Charlie__V
                      The toll for this bridge is going to be a lot of $.
                      One time use :~)
                      C
                      SketchyPhysicsBridge[2].skp
                        architectboy
                        Wow... what a balancing act... I like it... To bad it violates rule #1, but otherwise I like it. And I revised mine, it looks a lot better now.
                          CPhillips
                          FYI, You can make perfect arches if you use the convex hull shape. Here is an example:
                          arch1.skp
                            Krisidious
                            this is the kind of stuff I was talking about Chris... testing shapes and systems... now make glue for me... and sand and water and wind and... and... yeah I know, I'm really happy to just have this.... but I can still wish...
                            By: Kristoff Rand
                              architectboy
                              Thanks for showing me what "convexhull" does, with that info I have revised it again.
                                CPhillips
                                Very nice! It looks elegant and its really stable. I vote for this one. πŸ˜„
                                  CPhillips
                                  Ok, so I'm playing around with my bridge destroying it, throwing the car around, etc. when I come up with the idea of rendering the bridge, and once I had a nice render of it I couldn't help but make one of it destroyed πŸ˜„ .
                                  These renders are pretty sweet. I assume it is Kerkthea?
                                    architectboy
                                    Yep, that's Kerkythea (you forgot the y). Are you working on yours, CPhillips?
                                      Charlie__V
                                      Convexhull:
                                      Is this simply a cube (re-assinged to covexhull)and the form adjusted as necessary?
                                      Forgive me if I have missed something obvious.
                                      C
                                        CPhillips
                                        Convexhull:
                                        C
                                        It doesnt have to be a cube. Any shape will work. The easiest way to imagine a convex hulled object is to picture it wrapped in plastic. Here is a more detailed explanation:
                                        http://www.rustycode.com/tutorials/convex.html
                                        If you want to see what the physics engine thinks an objects shape is:Right click the object and select Debug->Readback Collision Geometry. Then press play.
                                        Chris
                                          Charlie__V
                                          Chris,
                                          Thanks for the info....and Thanks for a Really Cool Script :~)
                                          C
                                          • W Offline
                                            Will03
                                            Hey guys,
                                            This is my first time using this script, and I think i might not be adhering to all the rules of the program, but nonetheless here is my submission.
                                            Thank you for this great program! I love it!
                                            Will03Bridge.skp
                                            • 1 / 2
