    Justification of Dimensions
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    5 Posts 2 Posters 312 Views 2 Watching
    • SektaS Offline
      Sekta
      Hi All,
      Justification of dimensions in LO has stopped working for some reason, I can still use it with a text box but not dimensions. Is anyone else having this issue?
      Stan
        How are you trying to use justification for dimensions? The standard would be to have the dimension text centered in its text box.
        FWIW, if you have a multi line dimension text box justification works just fine.
        SektaS 1 Reply Last reply Reply Quote 0
        • SektaS Offline
          Sekta @Dave R
          Hi Dave,
          When I have small dimensions that are quite close I can justify one to the left and the other to the right so they dont over lap. What you are showing in your GIF above doesnt work anymore for me for some reason.
          Stan
            Dave R @Sekta
            @Sekta what operating system?
            Can you share a LayOut file with dimensions set up like you want? I'd like to see if it works differently on my end.
            Note in my gif it's only the short row of text within the text box that is moving. I wouldn't expect the text to move in the text box unless the text box was wider than the text. The text box for dimensions is normally just wide enough for the text so there'd be nothing to justify.
            You can move the text box along the dimension line or outside of the extension lines if needed.
            • SektaS Offline
              Sekta
              Hi dave,
              I was going to upload a basic p[an of my daughters house but when I adjusted the dimensions the justifcation worked so not sure whats going on. I have been having major issues with the new SU render engine which has screwed up a few of my files but I will do a separate post on this. I will investigate the dimension justification issue further and let you know what I find. Thanks.
              Stan
