    anamorfosi
    4 Posts 2 Posters 346 Views 2 Watching
      luisto
      How to do an anamorphosis, what is the correct procedure. Somewhere I saw that it's a photo-match application, but it's not clear to me. Could someone kindly explain the procedure step by step. Thank you very much.
      tuna1957T 2 Replies Last reply Reply Quote 0
      • tuna1957T Offline
        tuna1957 @luisto
        @luisto More information would be helpful. Are you just trying to create a 2D image that shows how the artwork would appear in the space ? Or do you want to create actual geometry in the model showing the actual layout the image in the 3D space. Posting some relevant images of exactly what you’re trying to achieve would be helpful.
        • tuna1957T Offline
          tuna1957 @luisto
          @luisto Did a bit of searching. Found some older posts asking about this. It led to the suggestion of a couple of plugins. TIG’s “Projection to Ground and Didier Bur’s “Projections”. Check into them.
            luisto @tuna1957
            @tuna1957 said in anamorfosi:
            Mille grazie.😊👍👋👋
