    Curic Extension potential Conflict
    1 Posts 1 Posters 198 Views 1 Watching
    • P
      pipinek
      Greetings,
      After having installed Menu Pie and other Curic extensions I have somme conflict issues.
      Once Curic Pie Menu Uninstalled all reverts to normal.
      There is no possibility to Disable the Pie Menu (Curic) because SU closes with BugSplat not saving changes.
      Please advise.
      Thank you in advance
      PS 1
      Is there any way to get email contact to a extension author (Curic)?
      PS 2 Laste version of Su and Vray used (6.2)
      Error: #<NameError: uninitialized constant VRay::GUI::EXPECTED_CALLER_LENGTH>
      c:/users/xxxxx/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/!curic_piemenu/override.rbe:397:in const_get' c:/users/xxxxx/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/!curic_piemenu/override.rbe:397:in block in set_vray_expected_caller_length'
      c:/users/xxxxxx/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/!curic_piemenu/override.rbe:541:in block in new' c:/users/xxxxxxx/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/!curic_piemenu/override.rbe:404:in block in set_vray_expected_caller_length'
      C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/main:24:in is_online' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/main:24:in init'
      C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:44:in block in <top (required)>' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/eula.rb:63:in ensure_accepted'
      C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:10:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2023/Tools/extensions.rb:197:in require'
      C:/Program Files/SketchUp/SketchUp 2023/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2023/SketchUp/Plugins/vfs.rb:28:in register_extension'
      C:/ProgramData/SketchUp/SketchUp 2023/SketchUp/Plugins/vfs.rb:28:in <module:VRay>' C:/ProgramData/SketchUp/SketchUp 2023/SketchUp/Plugins/vfs.rb:4:in <top (required)>'
