    DC - onclick function - position update problem
    1 Posts 1 Posters 231 Views 1 Watching
    • P
      Pivonka
      Hello,
      I would like to ask for help. I have almost completed the dynamic component of the sliding casement window. I’m using the onclick function here for the wing to move the wing to the open and closed position.
      I also added the possibility of changing the dimensions with the SCALE tool with the limitation of the planes of action.
      Problem: after resizing via SCALE, wing position does not update with onclick function. To restore the position, you need to click again with the tool to update the new position. Is it possible to treat this?
      I am attaching the component.
      Thank you very much for any help.
      HS Portal DC 2.skp
