    Model slow to save
    3 Posts 2 Posters 167 Views 2 Watching
      tspco
      I have one particular model that takes way longer to save than most of the others, and some of the others are far more complex.
      Is there a way (plugin) to identify what the issue is, and then allow me to correct it?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • sketch3d.deS Offline
        sketch3d.de
        go to "Window > Model Info > Statistics > Whole Model" and hit "Purge Unused" to get rid of the unused stuff as materials or component definitions etc.
        You could also use TTs CleanUp plugin which gives you more information what is done during the cleaning.
        If nothing helps, unhide everything, switch on all layers/tags, select verything and copy to a new document.
          tspco
          I tried the Window Model info Statistics, purge all unused., We will see Thanks!
