    Two joins to play together on the same stave, in MsPhysics
    7 Posts 2 Posters 732 Views 2 Watching
    • G
      goran
      I'm trying to get two joins to play together on the same stave / rod / bar / thing...
      ...using Sketchup 2017 (which is the only capable version to play along) with extension MsPhysics.
      1 picture says more than 1000 words and 1 film says more than 1000 pictures, so 1 film says more than 1000000 words.
      Now to the movie
      https://drive.google.com/file/d/1lWzBXhU46_E2FQ3zuHV0Iawyeq1UPywH/view?usp=drive_link
      This feels like basic course 1A in Joins but can anyone see what I'm missing here?
      Also, kindly see attached .skp-file if you feel like fiddling a bit .
      Any help or thoughts are greatly appreciated πŸ˜„
      Thanks in advance πŸ˜„
      BR / GΓΆran
      Two joins, SketchUp, MsPhysics.skp
      • ecatiE
        ecati
        Do you want to do this?
        Click on the picture for animation.
        Two joins, SketchUp, MsPhysics_ecati.skp
        • G
          goran
          Yes yes yes !!! How how how ??
          I believe the answer of this will make several of my project blockers become non-blockers πŸ˜„
          / g
          • G
            goran
            My higher intent is to make an eccentric joint hinge like the ones in kitchen cupboard doors.
            see attached image
            Should I go "into" the component perhaps, and place the hinge inside it and also connect it from the inside to another component placed on the outside?
            BR / g
            • ecatiE
              ecati
              The hinge and part must be a group.
              • ecatiE
                ecati
                Maybe it could be this way.
                test.skp
                • G
                  goran
                  Hi Mr Magician,
                  Thank you. You are better than best. Your help has allowed me to silence the lambs.
                  Thanks again πŸ˜„ Have nice weekend πŸ˜„ πŸŽ‰
