πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Two joins to play together on the same stave, in MsPhysics
7 Posts 2 Posters 4 Views
    goran
    I'm trying to get two joins to play together on the same stave / rod / bar / thing...
    ...using Sketchup 2017 (which is the only capable version to play along) with extension MsPhysics.
    1 picture says more than 1000 words and 1 film says more than 1000 pictures, so 1 film says more than 1000000 words.
    Now to the movie
    https://drive.google.com/file/d/1lWzBXhU46_E2FQ3zuHV0Iawyeq1UPywH/view?usp=drive_link
    This feels like basic course 1A in Joins but can anyone see what I'm missing here?
    Also, kindly see attached .skp-file if you feel like fiddling a bit .
    Any help or thoughts are greatly appreciated πŸ˜„
    Thanks in advance πŸ˜„
    BR / GΓΆran
    Two joins, SketchUp, MsPhysics.skp
    • E Offline
      ecati
      Do you want to do this?
      Click on the picture for animation.
      Two joins, SketchUp, MsPhysics_ecati.skp
        goran
        Yes yes yes !!! How how how ??
        I believe the answer of this will make several of my project blockers become non-blockers πŸ˜„
        / g
          goran
          My higher intent is to make an eccentric joint hinge like the ones in kitchen cupboard doors.
          see attached image
          Should I go "into" the component perhaps, and place the hinge inside it and also connect it from the inside to another component placed on the outside?
          BR / g
          • E Offline
            ecati
            The hinge and part must be a group.
            • E Offline
              ecati
              Maybe it could be this way.
              test.skp
                goran
                Hi Mr Magician,
                Thank you. You are better than best. Your help has allowed me to silence the lambs.
                Thanks again πŸ˜„ Have nice weekend πŸ˜„ πŸŽ‰
