    Perlin noise installation
    1 Posts 1 Posters 182 Views 1 Watching
    • J
      j_jones
      Hello Sketchup Friends!
      I found this cool project in github that will let you play around with perlin noise.
      https://github.com/huseyinbicen/Sketchup-Ruby-3DTerrain-via-Perlin-Noise
      It says in the installation instructions to add the files in the "lib" folder to the "Ruby library."
      Then gives this example:
      1-) C:\Program Files\SketchUp\SketchUp 2015\Tools\RubyStdLib Open Directory 2-) Move the "perlin_noise.rb" and "perlin" files in the "lib" folder to the directory in step 1.
      But I have no such folder in my directory trees for Sketchup.
      ./Library/Application Support/SketchUp 2017
      ./Library/Application Support/SketchUp 2017/SketchUp
      ./Library/Application Support/SketchUp 2017/SketchUp/Materials
      ./Library/Application Support/SketchUp 2017/SketchUp/Plugins
      ./Library/Application Support/SketchUp 2017/SketchUp/Styles
      ./Library/Application Support/SketchUp 2017/SketchUp/Components
      ./Library/Application Support/SketchUp 2017/SketchUp/Autosave
      ./Library/Application Support/SketchUp 2017/SketchUp/Classifications
      ./Library/Application Support/SketchUp 2017/SketchUp/Templates
      ./Library/Application Support/SketchUp 2017/WebCache
      ./Library/Application Support/SketchUp 2017/WebCache/GPUCache
      ./Library/Application Support/SketchUp 2017/WebCache/Dictionaries
      ./Library/Application Support/SketchUp 2017/WebCache/Local Storage
      ./Library/Caches/com.sketchup.SketchUp.2017
      ./Library/Caches/com.sketchup.SketchUp.2017/fsCachedData
      As for Ruby the language, I could only find these dirs
      ./.gem/specs/api.rubygems.org%443
      ./.gem/specs/api.rubygems.org%443/quick
      ./.gem/specs/api.rubygems.org%443/quick/Marshal.4.8
      ./.gem/ruby
      ./.gem/ruby/2.3.0
      ./.gem/ruby/2.3.0/cache
      Can anyone tell me where I might put these perlin noise filees so they could be used by Sketchup 2017?
      Thank you for any hints
      j_jones
