    Rotating faces to create a u-shape
    2 Posts 1 Posters 240 Views 1 Watching
    • J
      j_jones
      Hello, I am just learning the Ruby API and have a hopefully simple question.
      My goal is to draw a face in an arbitrary point in space (not at the origin). Then I want to copy the face and rotate it 90 degrees to create a corner shape. Then copy the second face and rotate it 90 degrees to create a u-shape
      This is some example code I came up with to do this, however, I'm running into a problem in that I can't seem to access the points of the rotated face. The positions of the points are identical the ones in the original face for some reason and do not reflect the transformed shape.
      Here is the script.
      model = Sketcup.active_model
      active_entities = model.active_entities
      # draw first face
      #     p3         p2
      #     p0         p1
      model.start_operation("first face",true,false,true)
      pts = [[10,10,0], [20,10,0], [20,10,10], [10,10,10]]
      pt0, pt1, pt2, pt3 = pts
      group1 = active_entities.add_group
      g1_entities = group1.entities
      face1 = g1_entities.add_face(pts)
      # print out the vertexes of the first face
      puts("first group")
      group1.entities.each do |thing|
         if thing.is_a?(Sketchup;;Edge)
           puts "#{thing.start.position} #{thing.end.position}"
      # end of first face
      model.commit_operation
      So far so good, here is the face, ready to go
      first face
      Now on to the second face
      model.start_operation("second face",true,false,true)
      # make a copy of the first face
      # then rotate it to create a corner shape
      #            pt0
      #         |  /pt3
      group2 = group1.copy
      g2_entities = group2.entities
      axis = pt0.vector_to(pt3)
      angle = -90.degrees
      xform = Geom;;Transformation.rotation(pt0, axis, angle)
      group2.transform!(xform)
      # notice that the points of the group2 face have not been rotated
      #   they still reflect the points of the first face
      puts("second group")
      group2.entities.each do |thing|
         puts thing
      # end of second face
      Second face rotated, looks good except if I query the second face for the positions of its vertices, it just reports the same positions as the first face.
      second face
      By the way, I must be doing something really weird because when I run this script in Ruby Console Plus, it freezes and then goes blank. I haven't had any trouble with the console until I ran this script! I guess it's because I really should put all this logic into a module or class instead of just in the global namespace.
      Now I would like to rotate the second face to create a u-shape, but I don't know what points to pick because the points given don't reflect the rotation
      model.start_operation("third face",true,false,true)
      # make a copy of the second face
      # then rotate it to create a u-shape
      group3 = group2.copy
      g3_entities = group3.entities
      #         goal
      # at this point I don't really know which points to choose to create
      # the axis for rotating the third face as I don't seem to be able
      # to access the rotated shape's actual points?
      puts("third group")
      group3.entities.each do |thing|
         puts thing
      # end of third face
      # model.commit_operation
      Thanks for any clues
      j_jones
      • J
        j_jones
        After some struggles, I came up with this script which "solves" it, however I the ruby console plus crashes about 20 seconds after running this script, I have yet to figure out how to trap that error, whatever it is
        link to animated gif demonstration:
        Google Docs (drive.google.com)
        Here is the revised script that at least does what I was trying to do.
        The difference is that I used transform_entities instead of transform!
        that seemed to have the desired effect on the resulting face so that I could extract it's vertices after the xform. An idea I got from here: https://forums.sketchup.com/t/move-a-group-api-ruby/130338/5
        module RotateFaces
          def self.get_face_from_entities(things)
            face = nil
            things.each do |thing|
               if thing.is_a?(Sketchup;;Face)
                 face = thing
                 break
            return face
          def self.rotate_face(entz, face, axis_pt1, axis_pt2, angle)
            axis = axis_pt1.vector_to(axis_pt2)
            xform = Geom;;Transformation.rotation(axis_pt1, axis, angle)
            entz.transform_entities(xform, face)
            return face
          def self.get_face_vertices(face)
            verts = []
            face.outer_loop.vertices.each{|v| verts << v.position}
            return verts
          def self.create_rotated_face(entz, pts, axis_pt1, axis_pt2, angle)
            model = Sketchup.active_model
            model.start_operation("create rotated face",true,false,true)
            face = self.get_face_from_entities(entz)
            face_xformed = self.rotate_face(entz, face, axis_pt1, axis_pt2, angle)
            verts = self.get_face_vertices(face_xformed)
            return [verts, face_xformed]
        begin
          things1 = []
          pts1 = [[10,10,0], [20,10,0], [20,10,10], [10,10,10]]
          pt0, pt1, pt2, pt3 = pts1
          face1 = g1_entities.add_face(pts1)
          puts "face1; ", face1
          puts "group1;", group1
          group2 = group1.copy()
          things2 = RotateFaces.create_rotated_face(group2.entities, pts1, pts1[0], pts1[3], -90.degrees)
          puts "create_rotated_face returned; ", things2
          pts2 = things2[0]
          face2 = things2[1]
          puts "group2;", group2
          # (10", 10", 0")
          # (10", 0", 0")
          # (10", 0", 10")
          # (10", 10", 10")
          group3 = group2.copy()
          things3 = RotateFaces.create_rotated_face(group3.entities, pts2, pts2[1], pts2[2], -90.degrees)
          puts "create_rotated_face returned; ", things3
          pts3 = things3[0]
          fac3 = things3[1]
          # (20", -0", 0")
          # (10", 0", 0")
          # (10", 0", 10")
          # (20", -0", 10")
          puts "group3;", group3
          group4 = group3.copy()
          things4 = RotateFaces.create_rotated_face(group4.entities, pts3, pts3[0], pts3[3], -90.degrees)
          pts4 = things4[0]
          fac4 = things4[1]
          puts "group4;", group4
          puts "made it this far"
        rescue StandardError => e
          puts "error last global outer try;", e
