    [Plugin] Save group as component
    1 Posts 1 Posters 149 Views 1 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      I was searching for a plugin to save a single group as a component, but did'nt find one that really suit my need.
      if it can be useful to anyone, i share it here.
      Two versions provided: english and french.
      To install, unzip 'SaveGroupAsComponent.zip", delete the unwanted version, and just put the remaining rb file in your Plugin folder. Restart SketchUp.
      Usage: select a group and right-click, then choose option 'Save group as component' in the context menu (this option only appears when the selection contains a single group).
      Default name of the component is either the group's definition name or its instance name.
      The 'save panel' let you change the name and location of the saved component, if needed.
      Regards,
      English and french versions (a single scrambled file isn't allowed here)
      DB
