    2023 ver. shadows settings changing when using x-ray
    2 Posts 1 Posters 246 Views 1 Watching
    • SminkyS Offline
      Sminky
      Hello,
      This didn't use to happen with previous versions so I would think it's a bug.
      Way to reproduce:
      1)Set shadows on and shadow display "On faces" too. The other 2 don't matter.
      2)Switch to X-ray view. The shadows display settings will change to "On ground" and "On faces" will be disabled.
      3)Switch X-ray view off again. Before it used to switch "On faces" back on but now it will stay on "On ground" only.
      The previous behavior was much quicker so It would be great if it could be restored unless there is a reason for this change.
      Best regards.
      • SminkyS Offline
        Sminky
        I found another bug related to this.
        I am based in Japan so my normal geolocation setting give me a UTC +9 in the shadows panel.
        If I set this, save the model, close it, open it up again, I get a UTC -7 setting there.
        After, if I change to X-ray or other view style, it will go back to the correct +9.
        This is quite dangerous because if I don't change it back and run a script that uses this info, it will give completely wrong results.
        Please consider, best regards
