    How to move a group
    2 Posts 2 Posters 224 Views 2 Watching
      mr_Creator
      hi guyes
      I create a group and add to group face
      group1 = entities.add_group
      face = group1.definition.entities.add_face(f[0], f[1], f[2], f[3])
      Next I will rotate everything in this group
      [X_AXIS, Y_AXIS].each { |axis|
      	if not face.normal.samedirection?(Z_AXIS)
      	   if face.normal.perpendicular?(axis)
      		  angle = face.normal.angle_between(axis)
      		  angle = 180 - (angle * 180 / Math;;PI)
      		  rotation = Geom;;Transformation.rotation(group1.bounds.center, axis, angle.degrees)
      		  group1.entities.transform_entities(rotation, group1.entities.to_a)
      Next I need to move everything to the origin of global coordinates. How to do it?
      group1.transformation.origin have zero coordinats, but group1 is not at zero.
      how to move a group or its contents to another location?
      • Dan RathbunD Offline
        Dan Rathbun
        This line of code will create a new group at the origin of entities. If this is the top level model's entities, then this is the global origin. If it is some other component's or group's entities, then it is their local origin.
        @mr_creator said:
        group1.transformation.origin have zero coordinates, but group1 is not at zero.
        This confirms then that group1's origin is at the origin of the active edit context's origin.
        I'm not here much anymore.
