How to move a group
hi guyes
I create a group and add to group facegroup1 = entities.add_group face = group1.definition.entities.add_face(f[0], f[1], f[2], f[3])Next I will rotate everything in this group
[X_AXIS, Y_AXIS].each { |axis| if not face.normal.samedirection?(Z_AXIS) if face.normal.perpendicular?(axis) angle = face.normal.angle_between(axis) angle = 180 - (angle * 180 / Math;;PI) rotation = Geom;;Transformation.rotation(group1.bounds.center, axis, angle.degrees) group1.entities.transform_entities(rotation, group1.entities.to_a) end end }Next I need to move everything to the origin of global coordinates. How to do it?
group1.transformation.origin have zero coordinats, but group1 is not at zero.
how to move a group or its contents to another location? -
group1 = entities.add_groupThis line of code will create a new group at the origin of
entities. If this is the top level model'sentities, then this is the global origin. If it is some other component's or group'sentities, then it is their local origin.@mr_creator said:
group1.transformation.originhave zero coordinates, but group1 is not at zero.This confirms then that
group1's origin is at the origin of the active edit context's origin.
