    Section Plane crushes (I dont have second monitor)
    2 Posts 2 Posters 119 Views 2 Watching
    • I Offline
      izabelaolbracht
      Hi there
      the program freezes when the I'm placing the "Section Plane".
      I don't have second screen, never did.
      Worked just fine 2 days ago and now this...
      I've tried the solution with alt+spacebar and move key and it doesn't work... still frozen.
      I've tried albo updating styles in new scene according to this topic:
      https://forums.sketchup.com/t/section-cut-face-crashing/37316
      Nothing seems to work.
      Reinstalled twice...
      It happens with every file I have, I've tried also creating a new file, same..
      • BoxB Offline
        Unfortunately the Dialog for the Section Planes doesn't react to Windows/Preferences/Workspace Reset Workspace. But you can try it.
        As for the alt spacebar thing you need to be very specific.
        Create a section plane then hold down Left Alt, not Alt Gr if you have one, and tap Spacebar once
        Then tap the default letter for move in your language if it isn't english. You can check this with any window active by doing the Alt Spacebar thing and seeing what shows in the little dialog that appears, the correct letter will be underlined.
        Tapping m will activate an icon of four arrows
        Tap any arrow key will attach the four arrow icon to the lost dialog
        Finally allowing you to move the mouse without clicking until the dialog appears on screen, at which point you can click to drop it.
