    Dynamic component section cut issue
    2 Posts 2 Posters 176 Views 2 Watching
      makover
      Hello
      Have a series of dynamic beams I created to place them within walls. When I go to view a section cut the beam does not show and it's almost as if the section for the DC is just behind the section cut for the wall and there for blocked by the wall's section fill. anybody ever have this issue? The beams are sized to length using the scale tool so not sure if that is affecting it somehow. When I look in the Dynamic attributes the lengths are all correct (Len X)
      Thanks for any insight folks may have.
      Mark
      section cut 3 ply beam doesn't show up
      Beam is present within wall
      When I zoom in the section cut and fill for the beam is just ever so slightly behind the wall cut for some reason
      • P Offline
        pcmoor
        Can you attach the file?
