    Alarm for V-ray (SOLVED)
    6 Posts 2 Posters 6.9k Views 2 Watching
    • TaxT Offline
      Tax
      An extension witch plays some music or pop a msgbox once V-ray has finished render.
      Any aproach ideas on this?
      I found no prints of it on SU console but it has its own "V-ray progress window":
      Could we acess/detect its last logs?
      obs: I use V-ray 3.6 on SU2018 on Win10-64bits
      "Between cause and consequence, lots of connivance."
      "Never felt being on same level as others; just bc Ive never been."
      • TaxT Offline
        Tax
        Just realized V-ray changes its toolbar icons while rendering:
        bet the best aproach would be an observer; would appreciate help on coding it.
        • TaxT Offline
          Tax
          Realized that eventually it may end up on UI::Command class matter.
          So I'm thinking about a simplier (even shitty) workaround:
          1º aproach: observer
          2º aproach: toolbar class?
          3º aproach: pixel color <<<
          New questions: (assuming its always gonna be the same pixel coord)
          • How to read screen pixels? directly?
          • Screenshot? how to write and read?
          • is "color check at every 10s" a good practice? better suggestion?
          • TaxT Offline
            Tax
            (SOLVED)
            It`s actually pretty simple. Thanks to DanRathbun on:
            https://forums.sketchup.com/t/how-to-tell-if-v-ray-render-has-finished/133293
            if VRay;;LiveScene.active.rendering?
            	@Timer = UI.start_timer(5,true) {
            		if !VRay;;LiveScene.active.rendering?
            			print "Render is complete."
            			UI.beep
            			UI.stop_timer(@Timer)
            			break
            		print "V-ray render check"
            else
               print "Render hasn't started. Try again."
            Works like a charm!
            • Dan RathbunD Offline
              Dan Rathbun
              Just a note that calling the == method with a true or false argument for a Boolean conditional expression is considered poor practice.
              Ie, ...
              if VRay::LiveScene.active.rendering? == false
              ... it is completely unnecessary to make a method call here as the Vray::LiveScene method calls return a Boolean result and the interpreters if evaluates the Boolean expression.
              So the interpreter must evaluate an extra expression that is either:
              false == false or true == false
              I'm not here much anymore.
              • TaxT Offline
                Tax
                Thanks, its fixed now.
                You always pro 😄
