    MACOS problem with ANY C++ GUI Window
    1 Posts 1 Posters 12.2k Views 1 Watching
    • B
      Brighter3D
      I am using Fiddle to run C++ GUI code from SketchUp Ruby,
      on Windows everything is fine.
      On MacOs I found a problem I can not solve by months.
      After window is shown (by first toolbar button) for the first time and closed
      most of the SketchUp "Window" menu items get disabled.
      It gets disabled right after window is shown and do not get enabled anymore (even after window is closed).
      It looks like this:
      Problem screenshot
      Also when you try to do the same again (show window) by the same first toolbar button, window is not shown again, and there is no button event on the ruby side (even when you click the button).
      It looks like a SketchUp is broken in some way by using c++ GUI window (event loop maybe?).
      It happens not only with FLTK but also with other GUI's like:
      • Coocoa
      • OpenGl
      • Nuklear
      • ultralig.ht
      Minimal test plugin:
      Test plugin
      XCode source:
      https://drive.google.com/file/d/1exFrLjjPIBqwQA3XfsPQCIjVgltV8qLO/view?usp=sharing
      Any help is appreciated...
