    How to set color for DIMENSION_TEXT
    3 Posts 3 Posters 6.7k Views 3 Watching
    • K Offline
      kimdv
      Hello everyone!
      I created a Layout document by Ruby from SU, and added SU model to it. Then, I added dimension by using the following command:
      dim = Layout;;LinearDimension.new(start_2d, end_2d, start_offset_length)
      doc.add_entity(dim, layer, page)
      dim.connect(start_point, end_point)
      However, the background color and the border stroke of the DIMENSION_TEXT are always "red", as you can see in the attached file. It happened after I connect the ConnectionPoints (by using "dim.connect(start_point, end_point)" above.
      https://i.ibb.co/Q9tv2Dm/test1.png
      How can I set the color of the stoke and background to be "white" or none?
      Thank you very much for your help.
      test1.layout
      • Dan RathbunD Offline
        Dan Rathbun
        @kimdv said:
        Hello everyone!
        A Layout::LinearDimension object is a subclass of Layout::Entity, so it inherits the #style= setter method.
        Either create a new Layout::Style (or grab it's existing style via the #style getter,) and modify it. Then set it back upon the dimension object using the #style= setter.
        I'm not here much anymore.
          streamlinemyrei Newcomers
          In the tree view on the left, select the base dimension style and click Edit. Click the Text tab. In the Text Color list, select a color for the text.
