    [Plugin] LordOfTheToolbars - v3.0a - 21 Apr 26
    503 Posts 96 Posters 472.8k Views 94 Watching
    • N Offline
      nicolasberthier
      Thank you but this fix still doesn't work. You can have D5 for free at https://www.d5render.com/download
      To understand and reproduce the issue:
      1. Install the free D5 LiveSync plugin for SketchUp.
      2. It generates a folder named d5_converter inside the SketchUp Plugins directory.
      3. Start SketchUp.
      4. LOTT scans the Plugins directory, encounters the d5_converter folder, and attempts to open it as a file.
      5. This triggers the fatal Errno::EISDIR exception in lordofthetoolbarsmanager.rbe (ghost_command_register).
      The script requires a bypass condition (e.g., next if File.directory?(path)) when reading the plugin directory contents.
      • D5 Render : https://www.d5render.com/download
      • D5 LiveSync for SketchUp : https://www.d5render.com/livesync/sketchup
      • fredo6F Offline
        fredo6
        Can you try with LOTT v3.0c.
        N 1 Reply Last reply Reply Quote 0
        • N Offline
          nicolasberthier @fredo6
          @fredo6 Thank you, the fix works perfectly.
          Regarding future development, LOTT requires two long-overdue updates to maintain full compatibility with the current workflow:
          1. Integration of new native tools: Several recent SketchUp tools are currently missing from the LOTT catalog and must be added.
          2. Iconography update: The UI icons need to be refreshed to align with the current SketchUp environment.
          Again, thank you!
          • 22
          • 23
          • 24
          • 25
          • 26
          • 26 / 26
