    Twinmotion mapping issue
    3 Posts 2 Posters 6.8k Views 2 Watching
    • L
      I imported an SU model into Twinmotion and the mapping is screwed. I have attched images showing the problem. Does anybody have any ideas why this happened or suggest a fix?
      • jenujacobJ
        jenujacob
        I had a similar issue once and I belive I exploded the group and the problem got fixed. It might solve the issue for you as well.
        • L
          Thanks but the model was exploded. But I have the answer.......when you import the SU model you need to tick the "FixUV/Texture" box and all problems will dissapear. I was concerned as another fix was to project image as texture also works but would have taken a few hours on this model. I have attached where the "FixUV/Texture" is located and it needs to be set before importing.
