    Offset by material
    5 Posts 2 Posters 3.1k Views 2 Watching
    • deaneauD Offline
      deaneau
      HI, is this possible in SketchUp make 2017 and SketchUp 2019/2020?
      the yellow glass must be grouped in one group.
      if someone knows a plugin that can do this, please name it. thanks a lot
      Thank you for your support and stay healthy
      Dean
      p.s. this look in a simulation (Auran Trainz) like this. Image was from here
      https://forums.auran.com/trainz/showthread.php?131629-Snow-High-Valley-Distr-Ctr-(High-Resolution-950x532-Approx/page85
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
        rv1974
        It's almost instant procedure when used with shortcuts:
        "Select with the same material*"-> Group-> JPP (with border-NONE option ON).
        • deaneauD Offline
          deaneau
          yes this is ok however the offset for all shapes with the same color/material work only step by step. try to imagine you have a building with more than 1000 windows and doors. 😲
          tnx for further suggestions and answers.
          Stay all healthy, no matter where you live.
          Dean
            rv1974
            it seems to me there is something wrong in your workflow. There are tones of window makers, frame makers free and for $$. No need to do it manually.
            Another point.. you should make one developed window and then populate it around.Need variations? Take existing window and stretch it with 'stretch by area' plugin.
            Another point.. there're component replacement plugins, if you have simple windows already in place you can easily substitute them with complex one. Yes. Even thousands simultaneously..
            • deaneauD Offline
              deaneau
              hi RV do you have a list for all this plugins you have talk about?
              tnx Dean
