    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    REQ: How to Extrude two different faces
    5 Posts 3 Posters 4.7k Views 3 Watching
    • F Offline
      fitz101
      Pls can someone help me on how to extrude a profile with two different faces? In the image below, notice that the profile has two different faces and is at an angle. How can I achieve this clean on SU? Any plugin recommendation or process will be much appreciated. Thanks
      • N Offline
        nlipovac
        I would try Curviloft plugin, and use the tool Loft along path.
        Here is my try, and be sure to check first how a plugin works and install the LibFredo6 plugin first.
        https://sketchucation.com/plugin/1175-curviloft
        My try.
        • BoxB Offline
          Fredo's Curviloft
          Edit: didn't see the post above as I posted.
          • F Offline
            fitz101
            Wow. Thanks a lot box. How did you achieve the last process of getting usmoothed geometry?
            • F Offline
              fitz101
              Am not getting clean edges using curviloft with 4 lines selected as path, as in the attached screenshot above. Any other recommendation?
