    Follow-me twist problem
    27 Posts 5 Posters 8.5k Views 5 Watching
      OK: reloadable! πŸ˜„
      Just a question : does the section is on the good place or must be placed like that ?
      Or by it's gravity's center ?
      • T
        thegoodguy
        Looks good pilou.
        I finally got it done using TrueBend.
        Thanks.
          With section on the middle side ... path with 20 points against 200 points! πŸ˜‰
          https://images2.imgbox.com/6d/47/hMrcKzRK_o.gif
            Just for be sure : your dxf was made directly from SketchUP or from another program ?
              Many regulates can be done... πŸ˜‰
              This structure will be the SKP structure! πŸ€“
              https://images2.imgbox.com/da/64/BAQAY5NM_o.gif
              Here one...(skp file rendered)
              https://images2.imgbox.com/2d/cf/OGGhxqR7_o.jpg
              ps SKP linked
              pinky_ring.zip
              • T
                thegoodguy
                Hi pilou,
                Yes, it was exported from SU.
                  Thx for the info!
                  Dxf from SketchUp are specific because curves are polylines so numerous "control points" !
                  Maybe Circles and Arcs can be exported as real curves...
                  With this one by Joergberg πŸ€“ (for SU Make)
                  So circles and arcs are not "segmented" ! 😎
                  As we can see for the circle...that is a true curve!
                  • 2 / 2
