    [Plugin] Export XYZ format
    5 Posts 4 Posters 4.2k Views 4 Watching
    • Didier BurD Offline
      Didier Bur
      For my personal use, I had to write a little exporter to export SketchUp terrains to TwinMotion.
      I share it here, and since this is not a "true" RBZ extension, it will not be published on the EW. Unzip the archive before use.
      The pdf explains my experiments with TwinMotion exported that way, and how it works.
      Export XYZ.pdf
      Hope this helps some of you πŸ˜‰
      export_xyz.zip
      DB
        Absolutly marvelous for hobbyist to can use the free Twinmotion 2019! 😎
        So cool with your new plugin! β˜€
        • JQLJ Offline
          JQL
          Thanks Didier!!!!!
          That is an incredibly useful plugin!
          www.casca.pt
          Visit us on facebook!
          • P Offline
            psylo
            Hi !
            Thank you for this plugin, very usefull ! πŸ‘
            I used it to import a Sketch'Up terrain into Archicad, but it comes flipped along Y SketchUp axis. That's not a big deal as it's easy to flip in Archicad.
            There is a difference between Archicad and Twinmotion when importing some .xyz files ?
              Didier Bur
              Hi Psylo,
              Yes there is, and in TwinMotion as well. 😞
              I'm too lazy (for the time being) to provide the option to flip data around XYZ axes...
              DB
