    [Resolved] Paint internal faces ?
    4 Posts 2 Posters 1.9k Views 2 Watching
      Does this plugin is existing?
      For any reasons I need to paint the internal faces of a selection! πŸ˜„
      Here in Black but will be fine with any colors or textures/ materials
      • pbacotP
        If you want all the back faces to be particular color, change the default backface color in the style.
          Many thanks! Excellent! Bravo! Simplicity is always better! πŸ‘ πŸ‘ πŸ‘
          I presume that don't work for texture ? Tested seems not...
            In fact easy too : Select by material then Fill with a texture! πŸ˜„
            Damned : not so evident because selection color each face! External and Internal 😞
            OK that work like that : verso simple color
            Selection by Material (the simple color)
            Menu Material / Edit / use image of Texture
            et voilΓ  πŸ˜„
            Click image for animation! πŸ€“
